Voodoo3 3500 TV
sefnejvetsi
Voodoo3 3500 TV
Příspěvek od sefnejvetsi »
Cau, mam problem vzdy kdyz chci pustit Visual Reality, tak mi vypise tuto tabulku:
The overlay surface is no available at this time. This application will now close. You can try closing any other applications that may use the overlay surface (e.g. DVD players, 3-D games, etc.) and then restarting this application. If no other applications are using the overlay surface you can reduce the screen resolution, screen color depth, or monitor refresh rate and the start this application again.
a dal mi to nejde spustit. Muze mi nekdo poradit co stim?! Dela mi to to same jak ve Win98, tak i ve WinXP. Díky moc
najprv sa mrkni sem,a skontroluj si ci pouzivas spravne drivery.potom sa uvidi :D
plus:
official voodoo3 3500tv FAQ at www.3dfxzone.it píše: I am not able to run the TV application provided with the 3500 TV. I get an error that says "The preview window is not available" when trying to launch the application. Upon closing that window, I get a second error that says "The overlay surface is not available at this time".
The first thing to check is the color depth settings. The display needs to be set to 16-Bit High Color. If this does not correct the issue, the next thing to try is the posted web patch for the 3500 TV which updates the drivers. If that does not work, there may be a lack of support files for WebTV. If this is Win98, you simply need to install WebTV. If this is Win95, you need to update their OS with the latest service packs and updates from Microsoft's website. Then do a clean install of the video drivers.
a aj tu:
http://www.xs4all.nl/~jfeelder/voodoous ... e3500.html
edit: asi by som sa mal nastvat a dat dokopy poriadne FAQ na voodoo3 (3500tv).tych par teplych slov ktore tam momentalne robia hanbu nieje to prave orechove..
