System Shock Enhanced Edition
takze tu mame 21 vyrocie vydania povodneho System Shocka, a s nim aj GOG release:
je to cd verzia beziaca cez custom loader;
- the game runs natively under windows, no (slow) dosbox emulation
- toggle able mouselook mode (smart, auto-disables itself when the player is interacting with objects)
- higher resolution support, up to 1024*768 (able to set custom ones as well, even widescreen)
- windowed mode
- scaling smoothing/filtering
- remappable keys
- no resolution changing when entering full map
- resolution and other settings now stored outside the savegames, eliminating the need to always set them anew once a game is started
- storing the settings externally also allows the log audio to be enabled by default
- can make screenshots by hitting printscreen (stored in \res\gen)
- couple of fixes to scaling, brightness and onscreen text
ak niekto planoval playthrough, tak teraz je ten spravny cas.
- windowed mode
- remappable keys
Re: System Shock Enhanced Edition
to nikomu nevadí, že ti Poláci ukradnout komunitní modifikace, naplácnou to na hru a pak to prodávaj pro svou kapsu?
ziaden strach, vsetky pravne zalezitosti boli poriesene.
to by mě zajímalo jak
mají z toho ty modeři něco?
dobry pocit a "zasloužil se o stát"
prislusny modder spolupracoval na EE release, a predpoklad je ze si nechal zaplatit.
dnes by malo vyjst demo remaku;
tak su teda vonku zdrojaky SS1 - su kompletne, ale je to mac verzia, takze na nejaky rychly x86 recompile mozeme rovno zabudnut. NDS momentalne pracuje na windows porte, mal by vyjst niekedy tento rok (SS1 EE bude updatnuta automaticky), a vydaju aj updatnute zdrojaky - to znamena ze seriozny development z nasej strany zacne az potom (nema zmysel forkovat hned a robit tu istu robotu).
a mame tu avizovany oficialny source port SS1 - kazdy kto hru vlastni na steame sa moze prihlasit do bety a po zadani hesla (saltthosefries) by sa hra mala sama updatnut.
je to Mac edicia backportnuta na pc, bezi nativne, podporovane su moderne rozlisenia a vsetko co k tomu patri.
SS1 EE je momentalne na steame za 2.5E, cize pokial si niekto chce vyskusat NDS source port tak ma idealnu prilezitost.
port vyzaduje windows7 (s win7 platform update) alebo novsie, Net Framework 4.7 (alebo 4.7.2 ak sa 4.7 odmietne nainstalovat), VC++2015 a OpenAL, samotny port ale narocny nieje, a bez vacsich problemov bezi aj na zariadeniach s Atomom. podporovane je OpenGL (3.1) aj D3D, takze pokial ma clovek win7 alebo novsie, tak by to malo bezat na hocijakom krame.
tak source port je oficialne vonku: https://steamcommunity.com/games/410710 ... 5092416976
ak si niekto planoval prebehnut SS1, tak teraz je idealny cas.Higher resolution support up to 4K widescreen mode
Mouselook support
Rebindable keyboard/mouse/joystick commands
Adapted to Nightdive's KEX engine
Support for both Direct3D and OpenGL
Option to switch between hi-resolution Mac assets and the original DOS assets
Official support for fan missions and fan mods
New unified options menu that allows changing preferences before gameplay
Adjustable FOV (Field of View)
Smoother camera rotation and translation
Improved control scheme which allows faster and streamlined experience
Brand new achievements
In-Game remappable keys with three profiles to choose from: original controls, custom controls, and lefthanded controls.
Many original game bugs fixed.
