P: Q3D Obsidian200SBi,100% ok (sold/predane)
není co dodat
Zamčeno
..jediny 100% ok kus ktory mam na predaj,vyvolavacka je 75$ (tj povodna cena funkcneho kusu za ktoru som mienil predavat.pevne dufam ze to troska dvihnete hore,inak sa mi pre tie vadne kusy nepodari ani pokryt naklady :( ).sucastou karty je aj mercury riser (pre single kartu nepotrebny,ale preco nie).
postovne plati kupujuci,pripadne osobka na dalsom sraze (ak to neponahla).
karta (na obrazku nieje mercury riser,ten sa pripaja na ten vertikalny konektor hned napavo od GENDAC cipu):
mercury riser (nalavo,to vacsie vpravo je AA modul ktory nieje sucastou tejto aukcie):
Naposledy upravil(a) ps47 dne úte zář 25, 2007 12:57 pm, celkem upraveno 1 x.
ozzy
Příspěvek od ozzy »
75$
osckhar
Příspěvek od osckhar »
ozzy píše:75$
I bid $100.
Thank you,
Oscar
Pozdrav ze Španìlska
just FYI,the mercury riser card is included,the AAmodule is not.the rest should be self-explanatory :wink:
ozzy
Příspěvek od ozzy »
osckhar píše:
ozzy píše:75$
I bid $100.
Thank you,
Oscar
110$
osckhar
$125
..just FYI,tested:
hitman1 (native glide3x),running fine :D
quake3 arena (glide2x via wickedgl opengl miniport),running fine :D
incubation (native glide2x),running fine :D
using win98se,last q3d drivers+koolsmoky's glides..
ozzy
Příspěvek od ozzy »
130$
osckhar
$150
Oscar
osckhar
@ps47,
Can you try the 200SBi under WinXP with some native glide games?
Thank you,
Oscar
I'll do my best to get it running within 48hrs.now where did I put those spare rams and hard drives..
all three games from the previous test ran with no problems under xp,using koolsmoky's voodoo2 driver (this is the only driver up to date with proper Q3D support,so you dont really have a choice here).the pci bridge was installed by xp once I plugged in the card,after that I had to manually point the installer to the unpacked v2 driver (two times),and after reboot the card was seen by device manager as two regular voodoo2s.added the q3d registry vars from the readme,and I was ready to go..
also,I will end the auction tomorrow at noon,so if somebody wants to try his luck,this is your last chance..
aukciu ukoncim zajtra napoludnie,ak chce niekto este skusit stastie,ma poslednu moznost..
edit: card goes to osckhar,locking and talk to you via pm.
Zamčeno
