je to sice eng ale myslim ze kto nerozumi,domysli siUse notepad to edit hitman2.ini,and change (or add if not present) the following lines: DrawDll Renderd3d.dll to DrawDll Renderopengl.dll and ColorDepth 32 to ColorDepth 16
Save changes and exit notepad.Download the newest MesaFX,and put the opengl32.dll file and the correct glide3x.dll file to your Hitman2 folder.Create a *.txt file (run.txt for example) in the same folder,and put in following:
set MESA_FX_MAXLOD=10
Hitman2.Exe
Save changes and exit notepad,rename the *.txt file to run.bat,and launch the game via run.bat.Use LOW settings for the graphics options.
edit: len tu strelim maly edit ze problem bol nalezen a vyriesen
