IBM Daytona
Jakákoli problematika co se týká Voodoo 4 , čili VSA-100 & VSA-101
exxe
Příspěvek od exxe »
have some one from here a Voodoo4-2 4200 PCI, 16MB DDR SG-RAM ?
i need help with my
I dont think anyone here has an IBM daytona..
this should be moved btw.
exxe
Příspěvek od exxe »
damn :(
ps47: zaklel, neco jek kdyz mi reknem kuwa, toto bylo slusnejsi
exxe píše:have some one from here a Voodoo4-2 4200 PCI, 16MB DDR SG-RAM ?
i need help with my
Do you find more information or your card is not work/unstable?
ale vaaazne? :lol:
Já bych si protentokrát dovolil výjimečně souhlasit s -HoNY-...
ps47> Nikdo tu nechape Tvuj smysl pro humor, nejdou na Tebe deprese z jedinecnosti? :-)
to tie 12 hodinovky :roll:
bola to narazka na unreal2 (isnt "dam" one of the forbidden words?).
Naposledy upravil(a) ps47 dne pát bře 03, 2006 8:54 pm, celkem upraveno 1 x.
Petrik9
Příspěvek od Petrik9 »
Kdy budou asi screeny z testu?
exxe
Příspěvek od exxe »
ps47 píše: (isnt "dam" one of the forbidden words?).
not forbidden but bad :twisted:
ok, my daytona
i cant find Drivers working
i tryed 3dfx Voodoo4/5 1.01.00, 1.01.00, 1.04.00, Voodoo Driver God's 1.08.05, Nuangel5, x3dfx Voodoo4/5 V1.07.00b, x3dfx V1.07.00, AmigaMerlin 2.9, AmigaMerlin 3.0, AmigaMerlin V3.1-R11, SFFT Alpha 33 and SFFT Alpha 35.
on m$ windows 98 or XP pro SP1.
Boot ok, but when windows initilized the driver hung up
or a black screen
system is a ASUS A7N8X-VM-400 (nForece2 IGP)
AMD Athlon XP2800+
512MB RAM
onBoard GeFororce2MX, witha PCI card i cant disable it.
on a ASUS P2B-DS (i440bx) i get a black screen. and no peep.
no VGA- peep and no non-VGA-peep.
Heatsink for testing, safety first
a capacitor is missing, position C72, right from the BIOS chip.
but card run without it. will be fixed in near future
well,nice card,but definitely not 100% ok-as far as I remember,IBM daytonas should work (not flawlesly of course) under win9x.try fixing that capacitor..I'm pretty sure someone at falconfly's has one IBM daytona,maybe you should try your luck there.
prosim hodneho admina o promaz OT a IBM daytona problem splitnout do samostaneho topicu.dik..
exxe
Příspěvek od exxe »
falconfly has sell his 16meg SG Daytona. (and some other cards)
i tryed the same driver like FalconFly but it not worked.
some one from his forums told me the specs of the capacitor :D
..seems like the card wont work without it.
exxe píše:...
or a black screen
It looks as power problem with memory or damaged memory.
Please make hight resolutoion foto of position where is capacitor missing
//edit: its SDR or DDR version?
Please run computer with other power supply
//edit2: :idea:
exxe
Příspěvek od exxe »
-HoNY- píše:
exxe píše:...
or a black screen
this screen (or a black) i become only with installed drivers
capacitor is missing here
http://www.tdfx.de/hw_pics/voodoo4_4200 ... bsg_05.JPG
Power supply is a Enermax
35/35/33A
exxe píše: capacitor is missing here
10uF or 22uF typycaly installed on most card
R125 (near VSA101 on right side) - its damaged or only bad foto?
Card without drivers not using all capacity of your memory (POST, DOS or 640x480 16color in MS Win9x more then 1MB).
Problem is not with Enermax.... ....please turn on with other PSU
Mods please translete:
....Problém nezpůsobuje Enermax, ale způsob jakým vyrábí napětí - spínané zdroje vyrabí vysokofrekvenční rušení a to nemusí kartě vyhovovat -> proto bych zkusil jiný.... ;-)
exxe.....
I heard man who sells IBM 16mb Daytonas is not 100% good seller, some of daytona cards was not work - it was broken....but I do not remember who had it. :(
exxe
Příspěvek od exxe »
-HoNY- píše: 10uF or 22uF typycaly installed on most card
10µF 16V
-HoNY- píše: R125 (near VSA101 on right side) - its damaged or only bad foto?
R125 looks ok
I.C.
Příspěvek od I.C. »
The card is very sensitive to what motherboard is used, try a different one! I used the last 3dfx Win9x drivers (1.04) and a TX based motherboard with a 200 mmx to get mine working.
