http://www.guru3d.com/newsitem.php?id=3069
Nová generace ATi R5xx...
Tohle stojí za přečtení, jedna starší korespondence
(Sassen je ten člověk, co vydal ony "testy" ATi R520)
>> From: Sander Sassen - Hardware Analysis
>> [mailto:ssassen@hardwareanalysis.com]
>> Sent: 08 September 2005 09:14
>> To: Andrzej Bania
>> Subject: Editors Day
>> Will I be there is the question?
>> Sander Sassen
________________________________
> ----- Original Message -----
> From: "Andrzej Bania" <abania@ati.com>
> To: "Sander Sassen - Hardware Analysis" <ssassen@hardwareanalysis.com>
> Sent: Thursday, September 08, 2005 10:37 AM
> Subject: RE: Editors Day
>> Hi Sander,
>> We submitted a list of media in our region about a month ago - and it
>> was down to Munich to decide where to send invites
>> They have the budget etc
>> We will have very limited places on the day - so there willdefinitely
>> be a tour straight behind any main event to make sure we see as many
>> people as possible :~)
>> Kind regards,
>> Andrzej Bania
> -----Original Message-----
> Sent: 08 September 2005 09:39
> To: Andrzej Bania
> Subject: Re: Editors Day
> So you're telling me I'm not invited is that it? I feel an ATI column
> coming
> up, lets see if we can drop the stock price shall we?
> Sander Sassen
>> To: Andrzej Bania
>> Sander Sassen
>> Hi Sander,
>> Kind regards,
>> Andrzej Bania
> To: Andrzej Bania
> coming
> Sander Sassen
nekdo tady nebo casto i jinde (nechci ukazovat na analniho lulana) casto poukazoval na to ze x850xt popripade jine high end modely maj dvouslotove chlazeni narozdil treba od jednoslotoveho u gf7800xt.
No, ale dnes se divam na fotuky a rikam si ze mi na te x850xt neco nesedi a pak mi to docvaklo.
7800 sice ma jednoslotove chlazeni ne?, ale aby bylo funkcni, potrebuje nasavat vzduch "zezdodala" takze defacto musi byt sloty volne dva, kdezto x850 vzrch nasava "bokem" takze i kdyz je zespoda zcela ucpana , nemelo by to mit na jeji vykon (chloadice).
Tudiz, me z toho vypliva ze i kdyz ma 7800 jednoslotove chlazeni, ma defacto dvouslotove chlazeni => "naroky" sou stejne, opravte me pokud se pletu
Je to přesně jak píšeš, sám jsem na to několikrát upozorňoval, ale ještě u 6800U. Když dáš přímo pod ní jinou kartu, zvýší se Ultře teplota...
Stejně tak si někdo stěžoval, že po přechodu z ATiny se Silencerem na 7800GTX mu vzrostla teplota CPU skoro o 10°C, protože vzduch z GTXka (peak 100W) jde do case, kdežto silencer (stejně jako X850) ho vyfukujou ven.
Liší se to možným rozlišením, obnovovací frekvencí, pak třeba ještě různý scaler... jinak degradace kvality přenosem není, ale jen do toho okamžiku, kdy se úroveň signálu dostane pod určitou hranici (zřejmě by pak došlo k úplnému rozložení obrazu). Tahle hranice ale může být s různými kartami rozdílná, protože různé karty mají různě kvalitní/silný signál.
jj, tenhle článek je fajn
jinak v těch schématech jim chybí čip podporující dva dual-linked DVI... asi nepočítali s tím, že se něco takovýho brzy objeví
