Asi už se z toho zblázním =-O viz obrázek ;-) (3dfx hw pics)
opera all the way.once you pop,you'll never stop
.akonahle som si zvykol,uz nedokazem pouzivat nic ine.ani firefox.je sice pravda ze default nastavenie (vzhlad,rozlozenie panelov) mi moc nesedelo,ale teraz si to viem nastavit za 5 sekund,takze ziaden problem.exploder uz popravde ani neviem ako vyzera.oprava-pred par tyzdnami som bol nuteny ho pouzit,a citil som sa akoby som pisal lavou rukou (som pravak)
Naposledy upravil(a) ps47 dne stř dub 06, 2005 1:09 am, celkem upraveno 1 x.
Ten člověk mě zničí...
... aneb - 3Dfx Voodoo 4 "L" prototype
3Dfx Voodoo 4 "L" prototype vs. PowerColor "L"
edit: Dokonce i 3Dfx V4 "L" popdoruje jako PowerColor pouze 3,3V AGP...
Neříkej, žes někde tenhle chladič viděl posazený na kartě
> Did you customize that cooling solution on your own?
No, the heatsink and fan assembly are a prototype from an ex-3dfx V6K
engineer that was never used, indeed never even fitted onto a board till
now. There was only a handful made and I was lucky enough to score this one.
As a bonus, the card it is attached to is the very first 3700 that Hank
worked out the "PCI rework" modification on, I'm honored to own it. He was
too busy to rework a virgin card so sent this one instead.
Hank did the removal of the original heatsinks, removed some of the
accessory header pins to clear the sink, clearanced the area around the bios
chip and mounted the unit.
I made the standoffs, cleaned up and routed the fan wiring, cleaned up the
fasteners, reversed two of them so it looked better and added isolators on
the backside and added the support bracket. I also need to make up another
backplate with the correct round hole which I will do as soon as I find
another junk 5500.
The thing is prue overkill, even at full load the heatsink only hits 23F
over ambiant.
Tak proc máš napsaný v članku o VV ze je je to trafo, klonil bych se spis ke slovům jako "napájecí adaptér pro V5 6K"no-X píše:Samozřejmě stejnosměrný
a odpoved na první otázku?
Ted me napadla jedna vec k V3 MCM
Uprostred chipu je jenom VCC+ a GND
takze jednoduse receno je vsechny spojily v jedn vyvod (ne do zkratu
//nekde to mam nakresleny jak jsem to myslel hodim to sem...
''CONFIDENTIAL DO NOT COPY''no-X píše:Tos nakreslil sám, nebo někde našel?
ten obrázek je součásti databooku od Oblaka... bohuzel to bylo od napalnu a ne od avangeru ale to nevadi pro symbolicky zobrazeni to je pouzitelný
Něco jsem na to kreslil já (ty barevný patlaniny a BGA pouzdro
Naposledy upravil(a) -HoNY- dne čtv čer 23, 2005 3:14 pm, celkem upraveno 1 x.
