Multi GPU/vicejadrove grafiky
- swarm
- debílek nahoněnej
XAN: Intel dělal taky 486ky v otmhle pouzdře. Viz můj velmi starý notebook:
Já bych to typl možná na nějakou PC emulační kartu do Maca.
Jinak ty PC emulační karty byly tenkrát docela normální. Byla to v podstatě kompletní emulace PC v Macu. Tim, že to běželo takhle na příslušném HW, tak aspoň nebyly problémy s kompatibilitou emulátoru.
Tomu moc nevěřím, že by se jednalo o "jen grafickou kartu". Do Genesis MP se strkaly normální "apple" PCI grafický karty, takže to by to vypadalo spíš jako grafika do PCčka.ghost píše:tak google hovori, ze je to graficka karta pre multiprocikovy pocitac DayStar Genesis MP.
[WWW]
tak jo mas pravdu:
na tej karte co nahodil Vlask je tento procik
The PC Compatibility Card lets you use DOS, Windows 3.1, Windows 3.11, Windows for Workgroups, and Windows 95 applications directly on your Macintosh computer. It includes a high-performance microprocessor that’s compatible with the latest DOS and Windows software.
You can:
- simultaneously run the Macintosh operating system (Mac OS) and PC applications
- switch between the Mac OS and PC environments at any time without quitting the applications you’re using
- view the current environment on a single monitor, or view both environments simultaneously on two monitors
- use the same hard disk for both Mac OS and PC software
- use your Macintosh keyboard and one-button or multibutton Apple Desktop Bus (ADB)–compatible mouse with PC software
- use your Macintosh modem, monitor, and printer with PC software, or connect PC-compatible equipment
- with some models, use a joystick or other game controller with PC applications
- with some models, connect MIDI equipment
- add random-access memory (RAM) to the PC Compatibility Card
- add 1 MB video DRAM (service technician only)
- use the built-in Macintosh serial ports with PC software
- play and record from PC CD-ROM discs using an Apple CD-ROM drive
- copy and paste data between Mac OS and PC documents
- with some models, play Sound Blaster–compatible sounds and use Sound Blaster sound processing utilities
- communicate with network servers and other computers running PC software
